The Upgraded Version
Warrior X Pro is an upgraded version of Olight's revolutionary Warrior X. Warrior X Pro uses a newer high-discharge 5000mAh 21700 lithium battery, which can produce a maximum of 2.100 lumens of light, a maximum projection distance of 500 meters, and can provide 2A current for 100% faster charging than Warrior X. The Warrior X Pro at the bottom is longer than the Warrior X (a quarter of an inch). Warrior X Pro retains the classic features of Warrior X's sturdy, aggressive appearance, as well as a vibrating battery indicator, silicone tactical ring, and optional magnetic remote control switch, and redesigned the heightened tail switch to provide unprecedented intuition operating experience.
Superior Tactical Thrower
Rugged, sturdy, and durable, using IPX8 grade aluminum alloy shell, sturdy and durable, can withstand the rigorous 3-meter drop test. The IPX8 grade aluminum-alloy body has obvious knurled patterns to provide better grip. Warrior X Pro has unparalleled performance and indestructible construction, it is the ideal choice for professional hunting, search and rescue or when on duty.
Pro Battery to Keep
Warrior X Pro uses a customized 5000mAh 21700 lithium battery, which can produce an incredible 2.100 lumens output and a projection distance of 500 meters, allowing you to see under any harsh conditions.
Pro Charging to Go
The redesigned heightened tactical tail switch has stronger magnetism and aggressive body knurling, which can provide a firmer grip, thus providing you with a simpler interface and operating experience than ever. To make it still tail cap chargeable olight had to get this outer ring to be able to make contact with that charger so to do that olight raised these three nubs there and makes contact with that outer ring so that you can still charge it the operation on this light is pretty simple. The light turns green when it’s charged it’s red while charging. Learn more!
